Hi Guys,
I'm having a problem with the warm up enrichment in Tuner Studio. The last adjustable point on the graph for me is 60 degrees celsius. This isn't warm enough for my engine to cut off enrichment and as a result it runs rough between 60 and 80 degrees. I've tried dragging the point across and looked in the settings but I can't see what I'm doing wrong. Hopefully someone has a suggestions.
Cheers,
P
WE Enrichment Stopping To Early
Re: WE Enrichment Stopping To Early
Is this an MS2 / MS3? They are adjustable, MS1 would be hard coded to 71°C for max WUE temp.
If you open the standard Warm up wizard, you should be able to adjust the temps for all the points.
Perhaps post an msq.
