In the Tunerstudio logging menu, there's a somewhat handy option to invoke Megalogviewer to open a log file from the current project.
Can I configure that option somehow to invoke Megalogviewer HD instead of Megalogviewer MS, since I only have a licence for HD?
Megalogviewer HD shortcut
Baldur Gislason
Re: Megalogviewer HD shortcut
Actually, that slipped my mind.... I need to have it automatically find HD as well.
If MLV MS isn't installed, then it should let you browse to HD, and fire that. If MS is installed, it will always find that first and fire that.
However, thinking about it; you could edit the tsUser.properties folder, and edit the megaLogViewerLocation property to point to HD, then it will find and use that.
megaLogViewerLocation=c\:\\Program Files\\EFIAnalytics\\MegaLogViewer\\MegaLogViewer.exe
change to:
megaLogViewerLocation=c\:\\Program Files\\EFIAnalytics\\MegaLogViewerHD\\MegaLogViewerHD.exe
change to:
