Does anyone know "IF" the TunerStudio AutoTune feature uses the same algorithms as the MegaViewer VE analysis tool ???
If there is a difference, would someone kindly help me understand the differences ?
Thanks in advance,
-D
TS FE Auto Tune v.s. Viewer VE Analysis
1992 Mustang Conv,
363" Man-o-War (8.2"Deck), Dart Pro-1,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Innovate DLG-1 (dual WB O2)
Ignition LS2 coil on plug (Crank trigger+ Explorer cam sensor)
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Re: TS FE Auto Tune v.s. Viewer VE Analysis
They are very much the same except for the Lambda Delay table in TunerStudio vs a set number of records delay in MLV.
Does one have advantages over the other?LT401Vette wrote:They are very much the same except for the Lambda Delay table in TunerStudio vs a set number of records delay in MLV.
David
