In much the same way as TS logs and compares cells on the VE map (and suggests changing them so that measured AFR equals that on the AFR map), it would be a nice feature if TS could have a similar function to log an EGT channel to produce an EGT map. The purpose of this would be to then compare all of the cylinders against eachother as a tuning aid (perhaps after the event, i.e. perhaps as some form of custom scatter plot in MLV) or to flag up a warning if it persistently is out of a range previously logged if on the fly from TS.
I realise that one has to has to be aware of which side of rich versus lean the cylinders are, but the purpose is to look at differences between them, not any absolute value.
If it were a scatterplot, then perhaps instead of colour coding, an average value could be displayed on the screen at each position approximating the centre of the cells from a VE map. If such a feature could be generic addition to scatterplots and output as a VE style table, one could subsequently process them in Excel quite easily.
kind regards
Marek
EGT logging suggestion
Re: EGT logging suggestion
Hmm, it sounds like you may be looking for something like the Histograms in MegaLogViewer HD:
http://www.efianalytics.com/MegaLogView ... grams.html
It does indeed and it looks like you have already aticipated this some time ago.
Thank you.
kind regards
Marek
Thank you.
kind regards
Marek
LT401Vette wrote:Hmm, it sounds like you may be looking for something like the Histograms in MegaLogViewer HD:
HOW DID I MISS THAT?
was waiting that feature since 2011 http://www.msextra.com/forums/viewtopic ... =+logworks
When they were released? only in the HD version, right?
Robert
MS3x 1.4.1 | TS 3.0.28
