Tuner Studio 3, new feature list?
subwoofer
Post by subwoofer »
Phil, you did let a few cats out of the bag in http://www.msextra.com/forums/viewtopic ... 22&t=57765, are there any other news official or otherwise in terms of added or changed features?
You know I would like to see MAF autotune. Another thing that would be interesting is a capability to connect to dyno control and logging systems for stuff like realtime BSFC display. I really don't know if the dynos support live data streams like that, but if they do it would be a good feature.
When will you start releasing public betas?
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
Re: Tuner Studio 3, new feature list?
Actually, that post seems to have been TunerStudio 2.7. I think TunerStudio 3 will have even more awesomeness. :lol:
One thing I'd like to see is an integrated firmware loader.
subwoofer
Post by subwoofer »
Matt Cramer wrote:Actually, that post seems to have been TunerStudio 2.7. I think TunerStudio 3 will have even more awesomeness. :lol:
I noticed 2.7 too, but I am pretty certain Phil said the next release will be 3.0. :D I vote in support of the integrated firmware loader.
Joachim
1974 Jensen-Healey
Post by LT401Vette »
Yes, that will be there, it is what I am currently working on.
ashford
Post by ashford »
some simple maf tools would be nice. eg the ability to select values, multiply, divide, copy and paste would make things so much easier
subwoofer
Post by subwoofer »
Looking at the screenshot, I think that has already been done. Notice the +, - and x buttons?
Joachim
1974 Jensen-Healey
lagos
Post by lagos »
:yeah!:
jesse408
Post by jesse408 »
Any chances of a Lambda Delay Table tuning feature as mentioned in the past? That could be very helpful.
Thanks.
Tony Evo
Post by Tony Evo »
2 features very cool to add would the autotune of Accell enrich and time of injection angle
Blown88GT
Post by Blown88GT »
ashford wrote:some simple maf tools would be nice. eg the ability to select values, multiply, divide, copy and paste would make things so much easier
subwoofer wrote:Looking at the screenshot, I think that has already been done. Notice the +, - and x buttons?
Nope. MAF not MAT. 3rd on the Poll, http://www.tunerstudio.com/index.php/co ... eaturepoll
subwoofer
Post by subwoofer »
With all probability all 2D tables use the same code (anything else would be silly design and a lot of work for no gain), so it is likely to be there. I just checked the current release, and there are no value manipulation buttons there. So by the looks of things, all 2D tables have now gained the manipulation tools we know from the 3D tables.
Joachim
1974 Jensen-Healey
Fueler
Post by Fueler »
If it hasn't been mentioned I would like to see a Project "save as"
OezyB
Post by OezyB »
I really would like to have MAP as a trigger for SDCard logging so SDCard logging would start automatically when boost gets to a set point. Currently i can select between TPS and RPM, sometimes i rev high with only 10PSI (boost control is deactivated), and then i dont need a log. I just would like to have a log when i get a "Dangerous" Boost, like 25PSI or so.
Greets
subwoofer
Post by subwoofer »
Bumping this back to the top of the stack, have you got any news for us, Phil? What did you present at MegaMeet?
Joachim
1974 Jensen-Healey
Flow
Post by Flow »
I noticed in version 2.6.19 (with a MS2) that when you set your project settings to use Lambda instead of AFR. That under the menu Accel Enrich -> Time-Based Accel Enrichment the live graph still shows AFR next to TPSdot and MAPdot. It would be nice that this would also reflect your project settings.
Thanks!
Car: Renault Clio RS 172 2.0 16v N/A (182 RS exhaust manifold, 200 cel race cat., KTEC silent stealth exhaust, lightweight flywheel, QUAIFE differential)
ECU: MS2Extra v3.0 with firmware v3.4.0
Lambda: Innovate LC-2
papiogxl
Post by papiogxl »
Fueler wrote:If it hasn't been mentioned I would like to see a Project "save as"
This. It's kind of annoying trying to remember where my project is actually saved when I keep loading new firmware.
The Ratchet RX7
1988 RX7 powered by 12V VR6
Ms3x, ID1000's, e85, pt6266, NX wet kit.
Stock block w/ arp hardware
TH400
8.8 IRS
It's always under My Documents/TunerStudioProjects.
File --> Project --> Export Project Archive
That has been changed for TS 3.0 to:
File --> Project --> Save Car Project to File
nathanhardy
Post by nathanhardy »
When is tuner studio 3 expected release date?
98 VW golf gti vr6 turbo 8:5:1 cr ported and polished full ferrea race valves train 276 cams custom short runner intake Borge 366 sx-e turbo forge wossner pistons, balanced rotating mass, limited slip 6 speed deka 750Lbs injectors on ms3pro completed AWD swap
Shooting for beta release in Dec
