Hi, is there a way to update/tune the ignition map by the press of a key or two - id like to be able to move around the map using the cursor keys to select a cell, then use another key to change the value (up or down)
ie I don't want to use a mouse, enter numbers or have to see what i'm doing other than making sure i have the right cell selected
many thanks
Jeremy
noob question - ignition map table hot keys
1979 RS2000 mk2 (Megasquirted)
2003 BMW Z4
1986 Landrover 90
2003 BMW Z4
1986 Landrover 90
Re: noob question - ignition map table hot keys
On the 2D table view of tables like Ignitions spark, you can
increment the values using > or q
Decrement with < or w
The lower case version of < & > works as well (, & .) so you don't have to press the shift key.
If on the 3D view, the same keys work, or you can use Shift+Up/Down
Works great, thanks. Is there a way to adjust the increment size - I'd like to be able to increase/decrease by 1
2003 BMW Z4
1986 Landrover 90
2003 BMW Z4
1986 Landrover 90
The </> keys increment/decrement by 1 by default.......jeremyf wrote:Works great, thanks. Is there a way to adjust the increment size - I'd like to be able to increase/decrease by 1
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Right Click on the table, select "Set Increment amount"jeremyf wrote:Works great, thanks. Is there a way to adjust the increment size - I'd like to be able to increase/decrease by 1
