I have recently encountered an issue with AFR readings that has perplexed me for some time and someone on MX5Nutz suggested I head over here to post about it.
I've posted here in case its a Tunerstudio quirk but it may well be that my post is redirected to the tuning section if its felt to be a hardware issue.
I've been running a Reverant built MS2 on my supercharged 1.6 Mazda Eunos for about 4 months along with an Innovate LC-2 sensor for to monitor AFR. During this time I have autotuned the car using Tunerstudion to great affect.
However, I recently had some tuning issues with fluctuating idle which I solved but in teh the last week I have had severe starting issues whilst trying to set up cold start. These issues have been impossible to resolve as I am getting annomolous conflicting AFR readings on the tunerstudio dashboard. The needle on teh AFR gauge on my tuner studio dashboard show that teh car is running lean, indicting a reading of around 19, whilst teh numerical value in teh dassh face shows a rich reading of 7:40?
I have been unable to resolve why these readings are occuring. In my search for an answer I have discovered two other forum members who also have the identical problem. We are all running Innovate LC-2 but bought our MS ECUs from different reputable sources.
Anyone have any idea what is causing the odd split reading in tunerstudio?
Example dash:
Conflicting AFR Readings in TunerStudio - cause?
Re: Conflicting AFR Readings in TunerStudio - cause?
There is no peg on the limits... The gauge is wrapped around far enough below the 10:1 that 7.4:1 lands at about 18.6:1The needle on teh AFR gauge on my tuner studio dashboard show that teh car is running lean, indicting a reading of around 19, whilst teh numerical value in teh dassh face shows a rich reading of 7:40?
The next release of TS does have gauge pegs.
Can he for now just rescale the gauge to read lower?
of course.nathaninwa wrote:Can he for now just rescale the gauge to read lower?
