This might be already present and I just cannot see it.
I like to use the Grid data in 2D mode more so than the 3D mode. While watching engine behaviour it is great that the blue dot indicates where the value is being derived from as well as the percentages used of the cell when mouse over. What I cannot see is the calculated current value of the blue dot in 2D mode. You can flip to 3D mode to see it though I would rather not have to flip forward and back. It is possible to show the current value say top left corner just above the grid (as a suggestion)? Also for consistency lookup graphs would be good as well.
Thank you.
Request - 2D Grid show the calculated value
Re: Request - 2D Grid show the calculated value
In 2.6 there is not really a way, but that would be a pretty simple addition for the new version.
Thank you for your reply. If you could add it to your v3 development plan that would be great.
