When trying to install Jean's IOX, I got the following error :
It doesn't seem to accept the iox firmware somehow...
IOX can device installation fails.
Re: IOX can device installation fails.
It looks like your CAN ID's are not set up correctly or you have CAN_COMMAND set to off.
Are you talking to the IOx through the MS3?
Check the Project Properties (Press CTRL+P)
On the settings tab, make sure CAN_COMMANDS is Active.
Then on the CAN Devices Tab, the Main Controller CAN ID should be set to 0.
Then click on the IOx's CAN Device.
SERIAL should be off
The default CAN ID is 5, check that is set to that unless you have changed it.
Thanks Phill,
Meanwhile and after a lot of issues, Jean suggested I do a MS firmware update (I still had the factory ms firmware installed - v 1.3.4). Turned out that was the issue. I installed the 1.4 but seems that one has got can issues as well and going to install the beta 2 version asap.
