update to 2.9.113 not working Mac
I just upgrade my from 2.6 to 2.9.113 in my macbook and tunerstudio does no start a pop out says that tunerstudio.jar could not start and check console for posible errors.
Re: update to 2.9.113 not working Mac
How did you update? Auto update?
Were you running an installed OS X installer or a Linux version running by double clicking the jar file?
Do you know what version JRE you have installed?
i am running a jar file i use first auto update did not start again I delete the file downloaded a copy form the beta side try again without success.
java -version
java version "1.6.0_65"
Java(TM) SE Runtime Environment (build 1.6.0_65-b14-466.1-11M4716)
Java HotSpot(TM) 64-Bit Server VM (build 20.65-b04-466.1, mixed mode)
java -version
A 1.7 JRE is required.java version "1.6.0_65"
got it Ill let you know
can I use the lates jre or it has to be 1.7?
Anything 1.7 and up.
got it working thanks.
