TS3 Firmware loader request
I noticed last night that the "Next" and "Back" buttons are very close to each other when using the firmware loader, with smaller laptops it's pretty easy to accidentally hit back after loading firmware, then you're stuck waiting for it to load again. Not a huge issue, but it is an inconvenience.
The Ratchet RX7
1988 RX7 powered by 12V VR6
Ms3x, ID1000's, e85, pt6266, NX wet kit.
Stock block w/ arp hardware
TH400
8.8 IRS
TH400
8.8 IRS
Re: TS3 Firmware loader request
It really probably shouldn't let you go back once the firmware is loaded.
That'd work even better.
Thanks!
Thanks!
The Ratchet RX7
TH400
8.8 IRS
TH400
8.8 IRS
