Tunerstudio and Megalogviewer on Fedora 22
I have been running Tunerstudio successfully on Fedora Core 18 and then upgraded to FC22 and it worked no problem.
I have now done a fresh install of Fedora Core 22 and both Tunerstudio and Megalogviewer won't even start. Strace doesn't tell me anything useful. I have disabled selinux and firewalld but that doesn't help.
There must've been some package on 18 that doesn't come with 22. Any ideas?
Re: Tunerstudio and Megalogviewer on Fedora 22
Java 7 not installed perhaps ?
It has 8 so that might be it.
Actually, I think I was meaning 8.
I've attached an strace if that helps.
if in a terminal you type :
java -version
What do you get?
If you try to start TunerStudio by using this in the terminal from the dir of the jar:
java -jar TunerStudioMS.jar
Any resulting error?
java -version
What do you get?
openjdk version "1.8.0_91"
Openjdk Runtime Environment (Build 1.8.0_91-b14)
OpenJDK 64-Bit Server VM (build 25.91-b14, mixed mode)
Running the jar file directly has the same result, straight back to the prompt.
No error just return code 1
I've put the old HDD back and got an strace from a working run.
OK so it appears that FC22 and 23 desktop only have the headless version of openjdk installed by default!! For the love of Pete it's a desktop distro!!!
I installed the correct version and all is good.
Yikes, that would certainly do it.OK so it appears that FC22 and 23 desktop only have the headless version of openjdk installed by default!!
