Hello,
I'd like to k'ow if there is a possibility to use VE Analyze without have to click on the "apply" button each seconds ?
I'd like to have the option to "always apply".
Regards,
Manu
VE analyze automatic mode ?
Re: VE analyze automatic mode ?
I think if you leave the box clicked next to apply button it automatically updates ECU every few seconds. I'd only be game to do if your fairly confident with the AFR settings and O2 sensor.
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Yes, if "Update Controller" is checked, then it will automatically send the updates every 15 seconds.
This usually works well as it will have the controller closer to right in order to zero in on the best answer.
If you update too frequently, it interrupts the runtime input data.
