i am working on a obd interface board but keep getting a "getting bit option error PID_sel1" , root problem: index 119 , size:65 ?
PID_sel1 is a table variable
the error picks up on various variables even when the selection box is not using it! even clicking to save the tune brings it up
any thoughts
ini errors?
Re: ini errors?
Sounds like an ini error causing an IndexOutOfBoundsException.
The ini?
The ini?
Re: ini errors?
hi , i found the error by accident, there was no entry in the msq for those variables! oops!
i added them with a base table entry and the error has gone.
another question though is how or can i greyout/not allow a selectionfrom a variable list eg in the ini entry
obd_address00 = bits, U08, 1, [0:3], "0x**DF", "0x**E0", "0x**E1", "0x**E2", "0x**E3", "0x**E4", "0x**E5", "0x**E6", "0x**E7", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID"
obd_address01 = bits, U08, 1, [4:7], "0x**DF", "0x**E0", "0x**E1", "0x**E2", "0x**E3", "0x**E4", "0x**E5", "0x**E6", "0x**E7", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID"
so if obd_address00 uses 0x**E0 (entry 1) how or can i stop obd_address01 from being able to use the same entry?
they are selected from this code from the ini
dialog = ts_cid, "", yAxis
field = "TS CANID 0", can_device00
field = "TS CANID 1", can_device01
field = "TS CANID 2", can_device02
field = "TS CANID 3", can_device03
field = "TS CANID 4", can_device04
field = "TS CANID 5", can_device05
field = "TS CANID 6", can_device06
field = "TS CANID 7", can_device07
field = "TS CANID 8", can_device08
field = "TS CANID 9", can_device09
field = "TS CANID 10", can_device10
field = "TS CANID 11", can_device11
field = "TS CANID 12", can_device12
field = "TS CANID 13", can_device13
field = "TS CANID 14", can_device14
field = "TS CANID 15", can_device15
dialog = obd_id, "", yAxis
field = "", obd_address00, {can_device00}
field = "", obd_address01, {can_device01}
field = "", obd_address02, {can_device02}
field = "", obd_address03, {can_device03}
field = "", obd_address04, {can_device04}
field = "", obd_address05, {can_device05}
field = "", obd_address06, {can_device06}
field = "", obd_address07, {can_device07}
field = "", obd_address08, {can_device08}
field = "", obd_address09, {can_device09}
field = "", obd_address10, {can_device10}
field = "", obd_address11, {can_device11}
field = "", obd_address12, {can_device12}
field = "", obd_address13, {can_device13}
field = "", obd_address14, {can_device14}
field = "", obd_address15, {can_device15}
thanks
thanks
Re: ini errors?
There is currently no mechanism to do this.so if obd_address00 uses 0x**E0 (entry 1) how or can i stop obd_address01 from being able to use the same entry?
