TS3 Firmware loader broken OS X
Every time I try to use the firmware loader on my Macbook Air I get an error saying the processor couldn't be woken up.
Support the developers!
Re: TS3 Firmware loader broken OS X
What type of connection are you using?
USB/Serial. The first couple of TS3 releases worked fine I want to say it broke around .114 or so.LT401Vette wrote:What type of connection are you using?
I tried to recreate this issue with the Mac that we have here but it loaded 2 different version of firmware fine so if you could please try the following then send me your TunerStudioAppDebug.txt file. First open up your current project for your MS3 then under the Communications tab check Comm Debug Log then try loading the firmware again, once the loader is either done or errors out please send me the TunerStudioAppDebug file so we can take a look. The AppDebug log might be too large to upload to the forum so you can email it to me at support@efianalytics.com, just include a link to this forum post so I know what its for.
I can use the firmware updater in my TS3 Ultra beta but it won't find the new firmware directly.
I have to download it first then browse to it on my laptop during the update process.
That is expected. The web service to download firmware is not yet available.gtmdriver wrote:I can use the firmware updater in my TS3 Ultra beta but it won't find the new firmware directly.
Ah!
Sorry about that.
Sorry about that.
So a quick update here along with an apology for the delay. I have tested 2.9.123's firmware loader with MS3 and MS2 but only the traditional variants ( no 3-Pro or microsquirt ) and it seems to be working just fine. I'm pretty sure the first time I noticed the issue it was trying to load firmware on a PnP2 so it could still be broken.
