Operating point indicator on Cell Weighting table?
Would it be much trouble to also have the operating point dot active on the Cell Weighting table on the autotune screen? (Would make it much easier to get the engine onto those areas that has not seen much exposure.)
Kind regards
Philip
Philip
Re: Operating point indicator on Cell Weighting table?
Not sure I follow?
While allowing Tunerstudio to autotune the VE table, you typically have the "Fuel VE table control panel" showing on the PC screen.
This screen shows the VE table being tuned quite large and on this table the engine operating point is indicated with a blue dot dancing around over that map. All good.
I would like to see a similar engine operating point blue dot also present on the smaller "Cell Weighting" map above right on that screen.
Therefore, if there are areas on the cell weighting map that are white or yellow, ie areas where the engine has not operated much to tune accurately there, having the active operating point on this table as well would make it be much easier get the engine onto those locations that need more time to tune.
Kind regards
Philip
Philip
Ok I get it now... Trace on the Heat Maps.
