Error saving project .. TS3 beta 2.9.124
"the requested operation cannot be performed on a file with a user-mapped section open"
This is the error I get when trying to open my project.
This is a Java error I think?
I dont get this error in TS 2.6.19
It started after updating from the last beta to 2.9.124.
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
Re: Error saving project .. TS3 beta 2.9.124
During opening a project?
You are getting a dialog popup?
Is your project on dropbox?
That error is known to occur during project saves, especially when the project is in a dropbox folder. That scenario is handled though.
Not on drop box ..
Might be in a different project folder though .. Permissions problem?
I'm running TS with admin privileges so it will update
Yes there is a dialog pop-up that requires a "ok" click to get past
This pop-up occurs after TS beta opens and after I click on the project I want to open.
TS3 will sometimes also hang when trying to open before I chose a project
On Windows? That should be needed and causes other problems. Try without doing that.I'm running TS with admin privileges so it will update
Is this consistent or sporadic? With all projects?
Windows 7 .. Happens sporadically
Only been opening 1 particular project lately.
I'll try disabling admin privileges and try other projects and report back
I've also noticed since updating to the latest beta that java has been using constant moderate cpu resources .. 25%-50% steady
There were few changes in the past beta, so I wonder what is up.
I am seeing the increased CPU usage, better than double 121...
I will look into that.
It appears the Thread to insure persistent channels like Odometer are persisted even in a harsh close was going in a hard loop.
This would basically send 1 core to full usage and cause continuous writing to the project.properties.
So I think this explains both of your issues. I'll get a fix out today.
Thank you much ..
