running tunerstudio through a tablet
Can you run tunerstudio through a tablet or do you have to go through shadow Dash
Re: running tunerstudio through a tablet
A windows tablet.
Ok thanks
I'm using a Dell Venue 8 Pro for two of my projects. Works well and battery life seems good
I run the 32gb units.
I got a tablet from Verizon Wireless that they gave me as a promotion but I don't know if it's capable of running tunerstudio
I use an ASUS T100. Battery life is good. Lot cheaper than a surface.
Cheers Luke
Cheers Luke
+1slow_hemi6 wrote:I use an ASUS T100. Battery life is good. Lot cheaper than a surface.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
I'm (also) using an ASUS T100 for my tuning laptop, running win 10. Small, just enough screen resolution, great battery life, bluetooth and a USB port (for firmware updates) cheap.
Keyboard detaches
Keyboard detaches
http://web.aanet.com.au/arran
Check out my tablet that I got from Verizon Wireless and it is actually a LG tablet and it does not have and I cannot get windows installed on it I may have to go out and buy a tablet that has Windows on it
