Hello,
what does TunerStudio request from the can device when i try to add one.
At the moment i think TS ask for the signature and the revision.
But in the ini file only the signature is covered.
BR
What does TS request for identify can device
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Re: What does TS request for identify can device
That's what it should ask for.
The serial format is to identify the correct ini file. The title is to show to the user.
Okay, because tuner studio pop up a message that there is no ini file for the device.
In the message box the revision and signature is one big string. Maybe thats the reason why TS is searching with the incorrect signature.
BR
BR
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Screenshot?
Device?
Comms log?
Device?
Comms log?
Hello,
i have a Megasquirt 3 TunerStudio is V2.9.127.
Screenshots attached. When i load the ini manual and then go online everything work okay.
TS have comm to the device.
BR
BR
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Code: Select all
private static final String infoCommand = "r\\CAN_ID\\x0e\\x00\\x00\\x00\\x3c";// Title bar, this is the code version.
private static final String sigCommand = "r\\CAN_ID\\x0f\\x00\\x00\\x00\\x14" ;// Verify against signature.
With Comm Debug turned on you should be able see just what is getting sent and received.
