dyno view in TUner Studio 3
my computer just updated to version 3.0.0 and when I opened my ve table it wasn't showing all the digits in the ve tables, any value above 99.9 was showing 10... or 11.... in the fuel tables, I found that enlarging the tables cleared this up in the main ve fuel table and in the fuel tab in tuning and dyno views, but the dyno dab is still showing the 10... and 11... in the fuel table and it isn't allowing me to simply drag the edge of the table to enlarge the viewing area and show the remainder of the numbers like the main fuel table and the fuel tab in tuning and dyno tab did.
Re: dyno view in TUner Studio 3
Did you maybe change look and feel?
no all that I did was click on the update now. I didn't change any look and feel or display characteristics, but my computer gets the auto updates from Microsoft and I am always having to reset the power and sleep settings, maybe one of their updates changed screen resolution or something.
What did you update from?
Nothing there has changed in months.
What look & feel are you using?
Please ignore - observation was made by an idiot at large (meaning me).
Dialogs were different sizes, therefore font sizes will be different. When I resized, the fonts were the same size.
I think I see the same with the VE table, needed to resize the table a little bit to show the full values.
If I compare the VE table with the ignition table, the font sizes are different. The VE table is using a larger font. Tony
my previous version was 2.9.128 or 2.9.130? .... and when it did the auto update check is said there was a newer version 3.0.0 so I told it go ahead and update to the newer version. I found that resizing my tables allowed the rest of the digits to be displayed.
I am using the default Metal look and feel.
the only ve table that doesn't show the full digits is the one in the dyno view. 110.0 shows as 11... and 109.8 shows as 10... and its only values more than 99.9 that lose the extra digits in the display
I have the same issue with the VE Table font size with the TS 3.0.01 update.
How can I change the VE Table font size or remove the bolding so the numbers fit in the table.
Erik
Erik
1988 Mustang, 357W Clevor, 12.5:1 pistons, 2bbl Cleveland heads, Street Boss intake converted to EFI, 30lb/hr injectors (Red Tops), MS3.57 Extra, Full Sequential Injection, 190L/hr pump, TFI, MSD 6AL, T5 transmission.
Hey Phil, I upgraded to 3.0.01 and the dyno view fuel table is displaying all the digits, thanks for your help.
3.0.02 probably?
I did loosen up the font sizing.
I haven't put that up for stable yet, but the beta is out there.
If all goes well, the stable will be up early this week.
