Temporary Project Problem
Phil, I downloaded the newest version as a trial and loaded an .msq today, and it automatically prompted for a temporary project and got the firmware definitions squared. At home I upgraded my registered version and it tried to load the .msq into my current project. Let me know if you need additional information to figure out what happened...
Re: Temporary Project Problem
If I understand you correctly...
On your home computer, if you double click an msq it opens TunerStudio, TS opens your project and loads the msq into that without ever giving you a prompt?
The prompt being: "Use Existing Project" or "Use Temporary Project"
I was thinking maybe if it was set to load last project on startup... But I tried that and can't reproduce.
What version does your TS on your home computer say in the title bar?
Is this repeatable? Any time you double click an msq, it goes straight into your project?
Yes, that's the issue. It loads any .msq into my current project and generates an error report but never prompts for a temporary project or attempts to download matching definition.
This occurred immediately after updating to the latest version after being prompted by TS when I started it up. I'll double check and make sure I'm not set to run betas or something but I'm 99% it was version 3.0.01. I'll check next time I remember.
It was repeatable, and it saved over my current tune when it loaded so I had to go back to a restore point to get my MS2 tune back after trying to look at an MS3 .msq.
Thanks!
Thanks!
Yeah it is 3.0.01 in Windows 10. I get a signatures do not match pop up box but nothing about loading a temporary project.
Let me know if there is a debug log I can enable and send you.
ETA: If I click on the .msq when TS isn't running it will load up and ask me about creating a temporary project.
