Trip odometer
Trip odometer
I noticed that my trip and odometer gauges in Tuner Studio started counting backwards. I deleted the gauges and created new ones but the values were the same and continued counting the wrong way. Also is there a way to reset the values?
Re: Trip odometer
That is an interesting one...
If you go into designer mode and right click on the gauge and select:
Dashboard Designer --> Set Long Click Action --> Reset Runtime Value
Then leave Designer mode...
Now if you click and hold the mouse down for 2 seconds on the gauge, it will reset.
Re: Trip odometer
So I noticed yesterday, I have a data logging button set up to data log. When I press it the trip and fuel ecom gauges go crazy
Re: Trip odometer
Do you mean an indicator that toggles logging on click?LSXCutty wrote:So I noticed yesterday, I have a data logging button set up to data log. When I press it the trip and fuel ecom gauges go crazy
Re: Trip odometer
Yes When I clicked it, The trip meter went to something like -220 miles on the trip and fuel ecom went to some high negative # as well
Re: Trip odometer
Which firmware are you running?
Re: Trip odometer
The latest release. 1.4.1 i think it is.
Re: Trip odometer
Were you able to replicate this?
Re: Trip odometer
Not yet...
I think it will take some real world testing.
I seem to be stuck behind a desk. I need time to play.
Re: Trip odometer
Got ya Thanks
