i have been fiddeling with a rasberry 3 and must say it worksvery well
i have the 7 inch touch screen which is not perfect but it works
so far the only issue ihave is that the upper part of the project properties are not showing and have no idea how to get them down
i can seem to grab and pull it down?
i can boot to a big monitor by disabling the touch screen and connect a monitor through HDMI
but thought maybe something can be done about it
i did not even have to install JAVA everything worked right out the box
Rasberry 3 tunerstudio project property,s tab not showing fu
Re: Rasberry 3 tunerstudio project property,s tab not showin
It looks like you just don't have enough screen resolution to fit things.
Try this from the main menu:
Options --> Preferences --> Settings Dialog Font Size
Set it to 8 or 9...
Set it to 8 or 9...
well 9 was still to high
i needed 8
you probably going to need glasses but you can do the important stuff
start/stop log
start/stop autotune
save/burn ecu
and the tables are now visible
i will need to set megelogviewer to the same font size
i needed 8
start/stop log
start/stop autotune
save/burn ecu
