That sounds like a permissions issue. Does your user not have write privileges to the /Applications dir?lutorm wrote:I have an update problem, too, but it seems to be different. The update fails with "Internal error: ./config.zip.temp.partial (Permission denied)".
This is on a Macbook pro running sierra.
TS 3.0.12 Update Problem
Re: TS 3.0.12 Update Problem
Ok... Mystery solved..
There was a bad entry in the database for the non-beta TunerStudio MS.
No jar file was getting downloaded.
Now it should update.
It's an admin user, but I don't think even an admin user can write to /Application without typing their password. When installing, you get prompted for the password. But I get no prompt when TS tries to update.LT401Vette wrote:That sounds like a permissions issue. Does your user not have write privileges to the /Applications dir?lutorm wrote:I have an update problem, too, but it seems to be different. The update fails with "Internal error: ./config.zip.temp.partial (Permission denied)".
Edit: I also can't find a more recent download than 3.0.01 on the TunerStudio downloads page, so I can't update manually.
The permissions in the TunerStudio MS.app folder are such that it does have normally write permissions. The OS X installers are a more time consuming manual process so are not built every release, thus depend on auto update to bring it up to speed.lutorm wrote:It's an admin user, but I don't think even an admin user can write to /Application without typing their password. When installing, you get prompted for the password. But I get no prompt when TS tries to update.LT401Vette wrote:That sounds like a permissions issue. Does your user not have write privileges to the /Applications dir?lutorm wrote:I have an update problem, too, but it seems to be different. The update fails with "Internal error: ./config.zip.temp.partial (Permission denied)".
The file it seems to be failing on is a temp file that is downloaded during the update.
Please work with support <at> efianalytics. com to get your install to update, I don't want to confuse this thread with a different issue.
I emailed them a week ago and heard nothing back...LT401Vette wrote:Please work with support <at> efianalytics. com to get your install to update, I don't want to confuse this thread with a different issue.
Update: Yes, it was a permissions issue. The installed dir was somehow owned by a nonexistent user, probably from the migration assistant. Works now.lutorm wrote:I emailed them a week ago and heard nothing back...LT401Vette wrote:Please work with support <at> efianalytics. com to get your install to update, I don't want to confuse this thread with a different issue.
Glad you got it working...
I wonder if the response went to SPAM. I will look into the response.
LT401Vette wrote:Ok... Mystery solved..
I have the jar problem. How do you make it update when you cant get into it? Or will it attempt itself. As a note it appeared to auto update when this happened, I hadn't used it.
Ok now reloaded version 10 and did update again all good......39ClevoUte wrote:LT401Vette wrote:Ok... Mystery solved..
This update contains protection against that for future updates, but this update would have been performed by the old code that if your connection gets interrupted it can end up with half a file.I have the jar problem. How do you make it update when you cant get into it? Or will it attempt itself. As a note it appeared to auto update when this happened, I hadn't used it.
Your fix is the best way to go for that, download the regular installer and run it.
Re: TS 3.0.12 Update Problem - Solved
Auto-updated to 3.0.14
No problems with updating, even with the primary laptop in the car in the garage over a wifi repeater at a slower connection speed.
