MS2 Extra FW 3.2.5 TS 2.6.19. The problem I am having is when TS is running with engine running.
When I open VE or AFR or anything the TS gauges freeze, but as soon as I close them the gauges resume working fine.
One time with the VE table open with engine running the VE changed to all zeros and engine died.
When this happened I was sitting still with engine idling not making any changes.
I reloaded the same tune and the VE table was correct but gauges still freeze with VE table open.
Something Strange Just Happened
Re: Something Strange Just Happened
It sounds like you may have turned on Modal Dialogs.
This option has been removed in TS 3+, but in 2.6 I believe it was under the menu:
Options --> Performance --> Modal Dialogs
