V3.0.15 Undo Redo buttons
Hi, I think there is a bug in this version because Undo and redo buttons are not availaible..
Do you have the same problem with this version ?
Re: V3.0.15 Undo Redo buttons
There does seem to be an issue with undo and redo.
Is there a link to download an old version ?
I found beta version link, but not official old version link
http://www.tunerstudio.com/downloads2/T ... 3.0.14.exetiti wrote:Is there a link to download an old version ?
many thanks
Or move forward... Undo redo is fixed in 3.0.16
LT401Vette wrote:Or move forward... Undo redo is fixed in 3.0.16
Just updated to 3.0.16 and now I have sync problems connecting onto MSPNP v3.57. Worked yesterday and now it connects then disconnects multiple times. What a pain as I was making progression with my tune and have time off over Xmas to play.
Jim
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Did you figure out what was causing your issue?
I'm pretty sure it is unrelated to the TS update, but would like to verify.
No havnt sorted issue yet. May be chasing a cable issue with micro USB connection.
Jim
Jim
Toyota MR2 98 3sgte
