After updating to v3.0.16 today, it looks like some gauges visibly show some placement constraints.
Maybe some debug code still in there?
My dashboard gauge looks like this:
v3.0.16 Problem with Dashboard
Re: v3.0.16 Problem with Dashboard
3.0.16 did contain a fix where gauges pointing at an invalid OutputChannel were not displayed as such, now they are again...
So it looks like you have a gauge that is pointing at an OutptuChannel that doesn't exist.
Go into designer mode, select the crossed out gauge and set it to a valid OutputChannel.
yup -
the component was just used for showing the digits on the dial and didn't specify an input - after selecting engine speed it cleared the framework.
Thanks.
Thanks.
