I have Time and Engine selected in the TS configuration for SD logging:
Without Time, dragging the mouse to the right shows the averages but does not show the time differential.
Older logs seem to work properly.
Are some fields being dropped?
But Time is not showing in the Log:
Time and Engine do not show anywhere in the data log file.Some SD Fields Not Recorded in Log?
Re: Some SD Fields Not Recorded in Log?
In my brief tests it seems that TunerStudio version 3.0.14.02 wasn't working, but 3.0.16 does work again.
That is correct.. It was fixed in 3.0.15jsmcortina wrote:In my brief tests it seems that TunerStudio version 3.0.14.02 wasn't working, but 3.0.16 does work again.
Great timing - I can confirm 3.0.16 has fixed the issue.
I had upgraded to 3.0.16 but was viewing an SD log from a couple of versions earlier. If I had waited a day or two after upgrading and gathered some fresher SD logs I wouldn't have noticed the issue because I would have been looking at a newly fixed log.
Thanks for fixing things before I report them so the turn-around-time is less than 0
