Multiple CAN devices crashes Tunerstudio
Re: Multiple CAN devices crashes Tunerstudio
I have finally been able to get a functional test setup with an MS2 and 2 TIOx. And I do get the same issue. Since the project backup is too big to attach it here, I'll email it to Phil together with the comm debug log.
Thanks a bunch man!
Were you able to test with alternative serial programmes, to see if you can get it to work that way?racingmini_mtl wrote:I have finally been able to get a functional test setup with an MS2 and 2 TIOx. And I do get the same issue. Since the project backup is too big to attach it here, I'll email it to Phil together with the comm debug log.
I'm not sure what you mean by that but I did try to run the exact same project using my USB-CAN adapter as the CAN passthrough device instead of the MS2 and I got the exact same result. So that, in my mind, completely eliminates the possibility that the issue is in the MS2 code and the only thing that remains is TunerStudio.jsmcortina wrote:Were you able to test with alternative serial programmes, to see if you can get it to work that way?racingmini_mtl wrote:I have finally been able to get a functional test setup with an MS2 and 2 TIOx. And I do get the same issue. Since the project backup is too big to attach it here, I'll email it to Phil together with the comm debug log.
I mean using standalone C (or whatever) code to send and receive serial commands.
No, I have not. But the comm debug logs do show that the commands are correctly sent and received; the issue is that TS declares an error that is not visible and does contradict the log.
I'll try to see if I can use the old TS version. Making my own PC test code seems a bit much at this time.
My best theory is if the outpc is the same size for both CAN controllers the error is triggered.
We are rigging up a setup with like firmwares on the CAN devices to try this out.
Yeah baby YEAH!
Apparently not as straight forward as 2 CAN identical devices.
We rigged up an MS2 running 3.4 + 2 MicroSquirts running the Trans code as CAN devices and all seems fine.
Still looking.
Still looking.
I haven't reproduced it, but based on the error message and stack _think_ I know the problem.
Old code that validates the runtime data read based on secl.
I should have a beta going out shortly to try.
Is there anything in the ini that would make that more problematic with the TIOx compared to the trans code ini?
Phil that is the exact same fault i told you a few weeks ago.LT401Vette wrote:I haven't reproduced it, but based on the error message and stack _think_ I know the problem.
I have testet much with can devices (my own devices) and TS is sowing a message that sec variable is not in the outpc for the can device.
But for me sec is not needed for my can device.
Hope you can fix this soon.
Thanks in advance
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Try the beta 3.0.16.06 I put up yesterday.
I fixed what I _think_ is causing it, but still haven't been able to reproduce it, so can't say for sure.
Holy fingers crossed Batman ....
Will test today!
Will test today!
kaplah on the initial test!!
I have successfully tested 2 Tinys. I need to build a couple of harnesses to get 3 going, will get to that at some point here over the weekend.
The default dash gauges are wonked a bit with this TS version.
Thanks Phil!
Thanks Phil!
How do you mean?Ted75zcar wrote: The default dash gauges are wonked a bit with this TS version.
What OS are you using?
Gauge needles are missing and replaced with smallish solid yellow circles. Could it be a limits thing? This is essentially on the bench, no sensor spoofing.LT401Vette wrote:How do you mean?Ted75zcar wrote: The default dash gauges are wonked a bit with this TS version.
Win 10
I just wanted to confirm that it is also working on my setup and the gauges are fine for me. I'm using the default dash and I'm on Win 7.
Ah ha!!!!! Seems to work ok here also!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Hello,
i have tested now my setup with 3 can devices attached.
2 of them are the same devices only different can id.
Everything looking god with this TS version.
Only thing which i have seen is when i disconnect 2 of the devices from the can and do a power reset,
TS only give the message for 1 device which is not reachable.
Best regards
Best regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
