Dyno view log gauge
Dyno view log gauge
Postby Zakari » Tue Apr 04, 2017 3:09 pm
Hello,
I'm trying to recreate this view :
But cant find this gauge style (log viewer in a dash ?)
Ideally I'd like to view multiple signals in the same spot to spot discrepencies easily (just like the view of AFR vs TPSDot from AE on the bottom right).
How can this be achieved in TS ultra ?
Zakari
Re: Dyno view log gauge
Postby LT401Vette » Wed Apr 05, 2017 8:06 am
It is the "Ling Graph" Style when in designer mode
Postby Zakari » Wed Apr 05, 2017 9:06 am
Thank you for answering this.
I might be doing something wrong but I don't see that style of gauge in designer mode :
Zakari
Postby sschutte » Wed Apr 05, 2017 10:06 am
You are correct the line graph type gauge template is not available under to the current Add Gauges dialog. Try these steps as a workaround:
1) Create a Needle Bar Gauge
2) Right click gauge > Dashboard Designer > Gauge Style > Line Graph
3) Right click gauge > (select the output channel you want to display in the graph)
4) Fine tweak size and colors as needed
sschutte
Postby Zakari » Wed Apr 05, 2017 1:12 pm
Aha this works thanks !
I'm guessing we dont have a feature yet to add multiple output on the same line graph ?
If we don't, could this be considered as a feature request ?
The dyno view is really useful when it comes to tuning static tables like spark or VE, but when tuning EAE on the dyno, I'd like to be able to plot MAP vs AFR while modifying EAE settings.
Again thanks for the help, it's already gonna make the tuning a lot easier.
Zakari
Postby WestfieldMX5 » Fri Apr 07, 2017 4:51 am
You can put several on top of each other.
Verzonden vanaf mijn iPhone met Tapatalk
'09 Westfield SEiW with '00 MX5 1.8 - 6sp - Torsen - MSM turbo - MS3 Pro - 3kg/hp
WestfieldMX5
Return to Tuner Studio
