Import table/dialog settings from msq
Like the title says, say I've opened VE Table 1, and Import Table. I would like to be able to select an .msq (not just a .table file), and then TS will automatically select and load VE Table 1 from that .msq. Same goes for File -> "Load dialog settings" - I should be able to select an .msq, not just an .msqpart, and TS will load the correct settings from that .msq.
The man behind MS Labs
Re: Import table/dialog settings from msq
That is how "Load Dialog Settings" works.Reverant wrote:Like the title says, say I've opened VE Table 1, and Import Table. I would like to be able to select an .msq (not just a .table file), and then TS will automatically select and load VE Table 1 from that .msq. Same goes for File -> "Load dialog settings" - I should be able to select an .msq, not just an .msqpart, and TS will load the correct settings from that .msq.
On any dialog if you use "Load Dialog Settings" you can load a full msq, but it will only load the settings in that dialog.
Awesome, great work!
