displaying current launch rpm
nathaninwa
Post by nathaninwa »
I have wired in a 0-5 volt reference wire to my I/O box using CANADC06. Id like to run a guage displaying the current selected rpm if we can. I run a windows tablet in my drag car and use TS as my dashboard
Attached is my current tune to make sure its wired right. I am not using generic sensor input, just having the 0-5 volt come in on canadc06 selected under variable launch
Re: displaying current launch rpm
There's no built-in method.
However, how about allowing input sharing and configuring that as a generic sensor, linear with the 0 and 5V values as your min and max launch numbers. (I haven't tested this.)
nathaninwa
Tried this out over the weekend, the variable launch works, but when I also turn on the input into he generic table to create a gauge, i get the dreaded input pin conflict error
I'll use some tape around the knob and write in what the current positions will be
Post by LT401Vette »
nathaninwa wrote:Tried this out over the weekend, the variable launch works, but when I also turn on the input into he generic table to create a gauge, i get the dreaded input pin conflict error
Did you turn on input sharing?
nathaninwa
I guess I'm unfamiliar with this feature. Where do I find it?
nathaninwa
Sharing input did the trick.
