Hi, In tunerstudio I want to add a gauge with live value ''pwm idle voltage compensation''.
Is it possible ?
I dont find the good parameter to assign to the gauge
Thanks.
PWM idle voltage compensation Gauge
Re: PWM idle voltage compensation Gauge
You can do that with the tableLookup function and the Channel Editor in TunerStudio MS Ultra
http://tunerstudio.com/index.php/manual ... -functions
Your expression would be:
tableLookup(array.idle_voltage_comp_delta, array.idle_voltage_comp_voltage, batteryVoltage)
So, create a new OutputChannel with this expression in the Advanced OutputChannel Expression Editor. Then create a Gauge Template and Data Log Field pointing to your new channel.
Does it mean it is only available in Tunerstudio ultra ?
It will work in any registered version, but you will need to create the custom.ini for the non-ultra as the Channel Editor isn't available.
Ok
Thank you for your help.
