wierdness with changing parameter after update
Postby nismoautoxr » Sun Sep 24, 2017 7:52 pm
Here is what Ive noticed. I can click on a box and enter a specific number and it will not accept it . The burn button will not light up . The box that I entered the number in stays white and the cursor continues to blink. When I close the box even after clicking the burn button I can bring the box back up and the original value is still there...not the one I put in.
If I click a box and then click the =, +, or - box and then enter the desired action the hit ok ...it will then accept the change and the burn button with light up. This has been the case with everything Ive tried to do whether it be a VE cell, a timing cell, a cranking duty setting, etc. Its only since the update that I recently put in last week. I am using 3.0.28. The controller is a MS3 W MS3X on 1.4.1 release firmware.
Ricky-
1995 Nissan 240sx, 403 LS strokerv8 N/A 6speed trans
MS3&MS3X v.3.0 PCB
42lb/hr Hi-Z inj.,230/232 @.050 on 114LSA cam
sequential fuel and sequential spark
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
nismoautoxr
Re: wierdness with changing parameter after update
Postby LT401Vette » Mon Sep 25, 2017 5:52 am
Re-check your version number.
Direct entry on tables is a known issue in the 3.0.50.06 beta, but not in the stable 3.0.28
There should be another beta update with this fixed this week.
Postby nismoautoxr » Mon Sep 25, 2017 9:03 am
I tried to attach a pic from my prone but.its too big.but.it is.definitely 3.0.28 that im using.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
nismoautoxr
Postby LT401Vette » Mon Sep 25, 2017 2:59 pm
Actually, I think it is look and feel dependent in 3.0.28.
With Metal Look & Feel the direct entry doesn't respond to the enter key. You have to hit an arrow key or click on another cell.
If you switch to the Windows Look & Feel it should work.
Postby nismoautoxr » Wed Sep 27, 2017 10:37 am
Gotcha. It really isnt a huge thing ...just wanted to make you aware it was happening.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
nismoautoxr
Return to Tuner Studio
Users browsing this forum: SteinOnkel, Yahoo [Bot] and 1 guest
