Registering TS on Windows 10 Tab
I just picked up a NuVision Windows 10 tablet. I got TS and Megalog Viewer loaded but I can't get it to register. When I click to add registration I get the pop up, but the tablet won't bring up the keyboard to input the information manually. If I select "Paste Email" it allows me to paste the info, but when I submit I get a message saying that I need to include all the info that I got in my registration email. But its all there..I have tried a couple of different ways but I am coming up short. Any advice? Thanks!
Re: Registering TS on Windows 10 Tab
I can't really do much with the keyboard part, that sounds like a tablet issue.
But with the paste..
What part did you paste?
You can select the entire email or part as long as it includes the
[Registration] and [End Registration] tags.
After pasting, if you switch back to the inputs, you will see what info it has imported from the paste.
Can't you simply change the tablet into behaving as desktop-mode instead of tablet-mode?
Thanks guys. I was able to kluge it by copy and pasting each line item into the manual entry screen. Not ideal but it worked. It’s my first tablet so I’ll try to see if desktop mode is an option
