VR VSS signal - Noisy when stopped
goodysgotacuda
Post by goodysgotacuda »
upload tune.msq
(266.23 KiB) Downloaded 29 times
I am trying to work through an issue that I have while stopped and my output shaft speed sensor.
My signal is excellent when driving down the road, but is extremely noisy while revving [stopped]. I can see up to 40mph when stopped and on the launch rev-limiter and a steady 2mph when idling. Currently I just have a twisted pair of wires, that runs within my entire engine "bundle" passing through the firewall. I am considering trying to fish some shielded cable through that bundle and rewiring it, but that is a last attempt.
Are there any settings here that I could look into to help that? I noticed that my TunerStudio manual image does not line up with my application, [see screenshot], perhaps VSS Sampling may help?
Screen Shot 2017-10-11 at 8.59.23 PM.png (313.74 KiB) Viewed 585 times
upload tune.msq
My log file is too large to upload and I am not sure how to shorten it.
firebird_1995
Re: VR VSS signal - Noisy when stopped
Post by firebird_1995 »
Subscribed for same exact issue.....
Sent from my SM-G900V using Tapatalk
slow94formula
Post by slow94formula »
Mine was noisy until I put a 10k ohm resistor across the wires.
LT401Vette
Post by LT401Vette »
Incorrect grounding can cause it, but I have had to use the 10k shunt as well.
goodysgotacuda
slow94formula wrote:Mine was noisy until I put a 10k ohm resistor across the wires.
I'll give that a shot, thanks!
