So for the second time today I have experienced this error dialog trying to import SD logs created from the same project just a few minutes or hours before.
I'm having to pull the card out of the MS3 because the the serial download is so slow and so prone to failing part way through.
Just wondering what is actually happening, because the displayed error message is incorrect.
Thanks,
Nigel.
Log File Signature does not match that of the project
- Attachments
- BadFirmware.PNG (110.35 KiB) Viewed 328 times
Re: Log File Signature does not match that of the project
Would need the .MS3 file to see for sure. Odds are it is a corrupt or empty file.
Make sure it isn't 0 bytes.
TS reads the Signature from the file header, so it is pretty close to the start of the file.
I'd guess you are right, I probably deleted the file after conversion (got so many I'm losing track). What would cause the corruption? The SD card wasn't removed until the ignition was shut off.LT401Vette wrote:Would need the .MS3 file to see for sure. Odds are it is a corrupt or empty file.
Thanks, Nigel.
Sent from my SM-N950F using Tapatalk
My guess is the file never had anything in it. It was created but never logged to?
Thanks Phil. Not sure how that would happen, the SD logging is triggered to start at something like 25rpm. I have pretty much the highest sales frequency so I doubt I could key on and off quickly enough.LT401Vette wrote:My guess is the file never had anything in it. It was created but never logged to?
