Error warning message
Philip Lochner
Post by Philip Lochner »
I get the warning message on project load despite Options / Advanced / Report INI warnings being switched off.
W10
TS: 3.0.28
FW : MSX 3.2.4
Kind regards
Philip
LT401Vette
Re: Error warning message
Post by LT401Vette »
What is the message? W10?
Philip Lochner
W10 = Windows 10 (Sorry!)
Error message attached.
TS error message.png (15.06 KiB) Viewed 454 times
Kind regards
Philip
LT401Vette
It won't prompt you on warnings unless it is turned on under the Advanced menu.
However, TS will always prompt you with Errors. In that screenshot there are 52 errors.
What are the errors?
Philip Lochner
custom.ini file attached. I can't figure out what the problem is.
52 Errors:
Error: Malformed [OutputChannel] entry, Problem at:
[custom.ini]:[Line:751]: entry = time, "Time", float, "%.3f"
[custom.ini]:[Line:752]: entry = seconds, "SecL", int, "%d"
[custom.ini]:[Line:753]: entry = rpm, "RPM", int, "%d"
[custom.ini]:[Line:754]: entry = map, "MAP", float, "%.1f"
[custom.ini]:[Line:756]: entry = throttle, "TP", int, "%d"
[custom.ini]:[Line:757]: entry = batteryVoltage, "vBatt", float, "%.2f"
[custom.ini]:[Line:759]: entry = afr1, "Actual AFR", float, "%.2f"
[custom.ini]:[Line:760]: entry = afrtgt1, "AFRtrgt1", float, "%.2f"
[custom.ini]:[Line:761]: entry = afrerr1, "AFR Error", float, "%.1f"
[custom.ini]:[Line:763]: entry = mat, "IAT", float, "%.1f"
[custom.ini]:[Line:764]: entry = coolant, "CLT", float, "%.1f"
[custom.ini]:[Line:765]: entry = engine, "Engine", int, "%d"
[custom.ini]:[Line:768]: entry = airCorrection, "Gair", int, "%d"
[custom.ini]:[Line:769]: entry = warmupEnrich, "Gwarm", int, "%d"
[custom.ini]:[Line:770]: entry = baroCorrection, "Gbaro", int, "%d"
[custom.ini]:[Line:771]: entry = gammaEnrich, "Gammae", int, "%d"
[custom.ini]:[Line:772]: entry = accDecEnrich, "AccelEnrich", int, "%d"
[custom.ini]:[Line:774]: entry = veCurr1, "Gve", int, "%d"
[custom.ini]:[Line:775]: entry = pulseWidth1, "PW", float, "%.3f"
[custom.ini]:[Line:776]: entry = dutyCycle1, "DutyCycle1", float, "%.1f"
[custom.ini]:[Line:778]: entry = advance, "SparkAdv", float, "%.1f"
[custom.ini]:[Line:779]: entry = coldAdvDeg, "ColdAdv", float, "%.1f"
[custom.ini]:[Line:780]: entry = tpsDOT, "tpsDOT", float, "%.1f"
[custom.ini]:[Line:781]: entry = mapDOT, "mapDOT", float, "%.1f"
[custom.ini]:[Line:782]: entry = iacstep, "IAC", int, "%d"
[custom.ini]:[Line:784]: entry = deltaT, "deltaT", float, "%.0f"
custom.ini
(30.85 KiB) Downloaded 22 times
Kind regards
Philip
Philip Lochner
I deleted all the datalog stuff and now my errors are gone. Am I right that the datalogging parameters in mainController.ini will still apply?
Kind regards
Philip
LT401Vette
It looks like your DataLog entries are in your OutpuChannels section.
did the [Datalog] section header get deleted?
Philip Lochner
LT401Vette wrote:It looks like your DataLog entries are in your OutpuChannels section.
Yes, I deleted that as well.
Kind regards
Philip
