first off let me introduce myself . I'm dave i work at a honda dealer in ny . i have a 2005 imreza with a 2003 ez30d swapped into it. now i have the ms3 .57 not the expansion board version.
I'm having a lot of issues with set up. so far i have set the fuel screen up with 6 cal fire order and engine size . etc
the ignition side now i have chosen 36-2-2-2 trigger offset to -1.5.
my problem is i get a not sync to sync problem when cranking it flickers on and off sporadically . i also have no pulse to injectors and coils. i could really use some advise i have pictures or my trigger log and set up parameters just don't know how to up load them
subaru ez30d and ms3 problems
Re: subaru ez30d and ms3 problems
if the ecu is not syncing up or is losing sync it will cut the injectors and the ignition. best thing would be to make a fresh set of logs, both tooth and composite logs and post those along with the current msq file.
http://www.msextra.com/forum-info/ shows how to upload the files as attachments.
