Hi Phil,LT401Vette wrote:Very important when you make a dash for Shadow Dash in TS:
You need to shape TS's dashboard close to the same aspect ratio as your target shape on Android. So, if you are going to use the dash in landscape mode, then when designing it with TS setup with a similar 16:9 aspect ratio.
If you use the alpha TS, when in designer mode it will tell you the dashboard size in the top right, so you can set it to 1280 x 720 or anything that maintains that aspect ratio.
It looks like in the screen shot of TS, that TS is setup up more or less square.
I downloaded alpha and set the screen to 1024x600 as my tablet screen size. I could make now a full screen fit dash but gauges still not overlapping as designed. Also the font type is different as I mentioned earlier.
Thanks,
Zoltan
