shadow dash usb
shadow dash usb
Is USB connectivity supported via the use of a serial to USB adapter that's using the prolific chip?
Re: shadow dash usb
Actually no, only FTDI cables.
I should add it would be a small effort. However I am usually discouraging the use of Prolific cables due to the BSOD bug they in their windows drivers. However they seem to have resolved those.
Re: shadow dash usb
It's worth nothing to mention that their Android drivers quality is about the same as Windows (AKA, terrible )
1993 Chevrolet Cavalier Z24
3400 Turbocharged Inter-cooled
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Re: shadow dash usb
Good to know. That tends to make it less simplistic.
Re: shadow dash usb
And they fundamentally change the API between point releases.
MSDroid More than just a dashboard.
Do you like the application? Make a donation to Cancer Research UK on our behalf http://www.justgiving.com/MSDroid/
Re: shadow dash usb
It was also "amusing" that while the excellent quality FTDI drivers are essentially handed on a plate, Prolific on the other hand want you to sign several NDAs and sign over your mother, child and right testicle for the privilege of having their shonktastic driver.
Re: shadow dash usb
If been trying this adapter with a Microsquirt today and I have to agree what a pos it is. Gunna bin it and drag a old laptop out that has a propper com port.
Re: shadow dash usb
Or just get an FTDI based adapter, you should get much better result
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Re: shadow dash usb
is there anything to look out for or just an adaptor based with the ftdi chip???
Re: shadow dash usb
Diy auto tune sell 1 that worked good for me using msdroid
Re: shadow dash usb
Here there is a bullit lust of things to watch for in order to avoid drop outs in noisy environments http://www.tunerstudio.com/index.php/fa ... nnectivity
Re: shadow dash usb
The real com port on the 15 year old laptop iv got works well with tuner studio for now
