Shadow Dash Beta 1.20 Registration code
Hi, I have received my registration code directly from EFI Analytics, and downloaded the beta of shadow dash directly from them.
Where and how do I input my registration code? I tried to select the Upgrades option in the Menu, but I can't figure out where to type it in. Help!
Jim
Jim
1968 Australian Morris Mini fitted with a 1310cc A+ engine
14point7 WB, TunerStudio MS Ultra & MegaLogViewer HD
My Blog: http://www.jims-blog.com
Re: Shadow Dash Beta 1.20 Registration code
I dont know if this is supposed to be correct or not but... When I loaded the 1.20 Beta on a new tablet I couldnt get something to run right - maybe it was the registration - so I removed it, installed the released version, entered the registration code and then re-installed the Beta. It worked fine I rationalized that the Beta may be missing a few elements (such as registration) that need to already be present since it not a released product.
A2 VW GTI 9A - MS3/3X
I hope not, I better check. I generally always have the registration inIt worked fine I rationalized that the Beta may be missing a few elements (such as registration) that need to already be present since it not a released product.
It seems Ok on the version I'm about to release.
Press the Menu Button, then select Upgrades. There is a "Enter Registration" option.
Well I don't have the "Enter Registration" option. What to do?LT401Vette wrote:It seems Ok on the version I'm about to release.
You do see the Upgrades menu?
When you click it, what do you see?
What version Android are you running?
JimLT401Vette wrote:You do see the Upgrades menu?
Yes
Upgrades
Performance 10Hz GPS
Get Connected - Proven R..
4.1.2
When you open it, does it say Demo!! In green letters at the top?
No
It sounds like your registration is already in.
Is there anyway to unregistered it?
Yes, delete the long named registration file in the dir:
/.efiAnalytics/
file name: com.efiAnalytics.shadowdashms.registration
/.efiAnalytics/
