Reading datalogs...
Reading datalogs...
MegalogViewer won't open my datalogs from Shadow Dash. MegalogViewer likes .msl files but SD produces .frd files. How is everyone viewing logs created by Shadow Dash?
Re: Reading datalogs...
You can convert FRD files to normal msl logs with TunerStudio. From the main menu:
Data Logging --> Import / Conversion
or shadowtuner.com will convert them. You can set SD to upload them automatically when you stop logging, they are then uploaded to shadowtuner.com and converted so by the time you get to the website they are waiting for you as msl file.
However, by default SD logs directly to msl files Unless you have the Preference "Use FRD Logs" checked. Go into Preferences and uncheck that option and all your logs from here on will be in standard msl format.
Wow...that was easy! I must have checked FRD logs as I was trying to get GPS to work. THANK YOU!
