shadow dash hibernation
Hi,there is a way to put shadow dash in hibernation when the ignition switch is off and back on and connect when the ignition switch is on?
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
Re: shadow dash hibernation
That sounds like this:
http://www.msextra.com/forums/viewtopic ... 33&t=53286
It is on the todo list to build it in, for now you need to use a 3rd party app.
Ok thanks Phil,can you point me to the right app I need?LT401Vette wrote:That sounds like this:
You try something like this:
https://play.google.com/store/apps/deta ... free&hl=en
I tri it out but seems I do not know how to do what I trying to do. I recently worked on a car with this holley lcd dash
it operates on Windows ce, after you open the holley tuning software and you turn the key off it stays in the same spot you left it and when you put back on it powers the screen back on an auto connect.How I can do this with shadow dash or tuner studio?
