My plan is disassembly an android celphone and put the screen behind the glass of the cluster.
I need change the dash screen of the shadow,
Request:
Change Shadow Dash screen's when vol.Up is pressed.
Change the bright of the phone when vol down is pressed.
If the request can be done, i can solder a wire and put a button outside of the glass to change the shadow screen's
Thanks.
Shadow resh ( Volume button + change screen ) request
Re: Shadow resh ( Volume button + change screen ) request
I imagine it can be done.. First we need to get the release supporting TS3 dashboards out.
Then what would you do about the conflict when SD supports audible alerts?
