maybe there´s already a way or tool to it .. I could like the "function keys" of the keyboard being assigned to tables from Megatune. So that with the strike of just one key I can call the VE-table or AFR-table or whatever - which is now a little difficullt to when on the run with the laptop on the passenger seat.
Somehow, maybe due to mainly driving alone, I cannot use the tuning-windows a lot. But I got used to the common AFR table so much that a glimpse would be enough to localise the bin in question on the move - give I could open the table fast enough, which I can´t do with the pull-down menues obviously and for safety reason.
Shortcuts to tables (by means of F1, F2, ... keys)
Range Rover Classic
Re: Shortcuts to tables (by means of F1, F2, ... keys)
User defined Hot Keys, I like that. I can probably put that into TunerStudio without much trouble.
And how about a shortcut key for starting a new log file without hitting enter for the file name.
1986 Porsche 944 Turbo
2.7 liter MID sleeved big bore, Wossner pistons, Vitesse Stage 2 turbo, coilovers, various weight deletes, and loads of other stuff.
