by KenAdkison » Fri Jan 27, 2012 8:06 pm
I have been having trouble shutting down TunerStudio in OSX using 1.14.1.
TS crashes each time I shutdown, using “File->Exit”. Using the Apple Window “TunerStudio MS -> Quit TunerStudio MS”, the application exits quickly.
After File->Exit, I watched the system monitor CPU load go up to 85% and memory usage near double before gave up and killed the task. I tried to reload the software but the results are the same.
I loaded Beta 1.21, it opened fine and shut down immediately using “File->Exit”. - Thank You!
