noob question here,
How do I graph "baro"? I have a seperate baro sensor and I would like to be able to see it, as I live in Colorado and can gain/loos lots of altitude in a single drive.
logging Barometer reading
'94 Miata ; 2001 VVT engine; DiyPnp 3.3.2 & VVTuner , 99-00 crank & cam sensors; sequential Toyota COP ignition; LC-1 wide band O2; Square Top manifold; RB header; Custom CAI.
Re: logging Barometer reading
It will likely take a custom ini with TunerStudio.
What firmware are you using?
MSextra2 3.2.2 beta
So if you just want to data log the barometer value that is displayed on the gauge, you need to add this to a custom.ini file:
I did it in the attached.
So now place this attached file in the dir:
[YourTunerStudioProjectDir]/projectCfg/
Make sure to rename it to custom.ini
Code: Select all
[Datalog]
; Channel Label Type Format
entry = barometer, "Barometer", float, "%.1f"
Thanks,
I appreciate all the help
Graeme
Golden, CO
Graeme
Golden, CO
