Bootload jumper needed with integrated firmware update?
If I use the integrated firmware loader in the current version of Tunerstudio, do I need to use the bootloader jumper on my microsquirt/MSPNP board? I have reason to think my firmware is corrupt and I want to reflash the board.
"87 Mr2
'96 Rav4
'65 Econoline Pickup
'75 Super Beetle
All Turbo, all the time
Why? Because I can...
'96 Rav4
'75 Super Beetle
Re: Bootload jumper needed with integrated firmware update?
The firmware loading process is the same, it just has a easier to use graphical interface. So, the boot jumper is needed in the same conditions (or not) as before.
The boot jumper only needs to be used if the firmware is totally corrupted and cannot be communicated with or if MS2/BG firmware has been loaded.
Thanks. I wasn't able to use the integrated firmware update. I got the message unknown monitor? I was able to reflash using the ms2loader_win32 without using the bootload jumper.
"87 Mr2
'96 Rav4
'75 Super Beetle
'96 Rav4
'75 Super Beetle
Please could you post more details so the TunerStudio developers can investigate.
As James said, you should only need a boot jumper if it had B&G Firmware on it or the firmware on it was corrupt enough it couldn't properly communicate.
Any idea what firmware you were installing and what was already on it?
I'm using Ms2/extra 3.4.2 on an older MSPNP system with the v1.1 Microsquirt board. I wanted to reflash the existing firmware because I suspected that it was corrupt. Probably doesn't matter, but I have registered copy of Tunerstudio running on a Dell laptop with Windows 10.
Screenshots:
Screenshots:
"87 Mr2
'96 Rav4
'75 Super Beetle
'96 Rav4
'75 Super Beetle
What version TunerStudio are you using?
I'm using version 3.0.22.
"87 Mr2
'96 Rav4
'75 Super Beetle
'96 Rav4
'75 Super Beetle
This unknown monitor issue is killing me. 3.4.2 firmware with 3.0.22 tuner studio. I feel like my firmware is corrupt because I can't change ignition timing when I change trigger angles (optical). No matter what I do the coil fires based only on physical changes (clocking distributor). It's like megasquirt is just instant firing. I hooked timing light to coil secondary wire to be sure it wasn't the cap and rotor.
I feel I need a jumper firmware flash but you guys say that is unnecessary.
Great Depression Racing
1992 Duster - 11.5@125 - The Junkyard
1994 Spirit - 13.8@108 - 6g72 Holset He341
1981 Starlet KP61
1981 Starlet KP61
Would someone that is seeing this please send a Comm Debug file?Ondonti wrote:This unknown monitor issue is killing me. 3.4.2 firmware with 3.0.22 tuner studio. I feel like my firmware is corrupt because I can't change ignition timing when I change trigger angles (optical). No matter what I do the coil fires based only on physical changes (clocking distributor). It's like megasquirt is just instant firing. I hooked timing light to coil secondary wire to be sure it wasn't the cap and rotor.
Otherwise it will not change.
