I've exported a log but don't see any difference compared to the original.
What does Export do, is it just copy ?
Export Loaded Log As
Re: Export Loaded Log As
If I'm not mistaken, Export is equivalent to Save As, which simply allows you to provide your own file name.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
so it's the same as copying the file ?
As far as I'm aware, if you trimmed the log, the Export will save that shorter trimmed version.
For the most part.W126 wrote:so it's the same as copying the file ?
And that also.jsmcortina wrote:As far as I'm aware, if you trimmed the log, the Export will save that shorter trimmed version.
As James said.. If you have edited the content of what is loaded, it will save what is now loaded.
So if you Trim after cursor, before cursor, etc... Those parts are gone and will not be saved.
Also your calculated fields will be saved to the new file..
thank you Phil
